Spin on adapter for IH 404?
Phil from Maryl
12-08-2004 14:43:46
I am getting tired of trying to make my filter not leaking when changing oil. Those O-rings that are used to seal the filter housing from the base are a pain. Where can I get a spin on adapter for an International 404 tractor? I checked here and they do not have one.
Thanks
Phil
tnrobby
12-09-2004 07:28:57
 Re: Spin on adapter for IH 404? in reply to Phil from Maryland, 12-08-2004 14:43:46
You can get the kit from the dealer the last one I got was about $50.00 you may have to get them to look it up in the 444 book but i have them on M'S and a 300. Good luck
Allan in NE
12-09-2004 05:06:32
Hi Phil,
I'll bet somewhere along the line, that someone has mistakenly put in two o-rings.
If you are having trouble sealing the can with the o-ring, betcha you are trying to seal against a rock hard old seal.
Normally, they seal up very easily.
Allan
CNKS
12-08-2004 17:54:03
There are adapters, don't remember the source. I have never had that problem, Case-IH filters come with a new gasket, be sure the old one has been removed, it won't leak.
