SMTA hydraulic problem
Alaskapete
12-08-2004 18:35:36
I am getting no flow through the hydraulic remote control valve. It seems as though the rod is not connected to the valve. I have opened the top of the valve box by removing three bolts and the square nut on the top of the box. My parts manual does not show the parts inside the box other than the centering spring assembly. How do all those parts work together to have the lever activate the valve? Thanks for your help.
Jerry G
12-09-2004 00:29:12
 Re: SMTA hydraulic problem in reply to Alaskapete, 12-08-2004 18:35:36
Hey Pete,
I have lived in Alaska for twenty yeas, and I have yet to see a SMTA up here. Now I guess there is two of them. I have a restored '44 H with a wide front and M & W hand clutch.
I am in the Palmer area, where are you?
Jerry
Alaskapete
12-09-2004 04:17:24
 Re: SMTA hydraulic problem in reply to Jerry G, 12-09-2004 00:29:12
I live in North Carolina, but my heart is in Alaska after visiting it four times.
Ken C.
12-08-2004 20:24:22
Alaskapete . . are you in Alaska? I live there and was just wondering. I also have an SMTA. Shoot me an email and lets talk.
Alaskapete
12-09-2004 04:23:03
 Re: SMTA hydraulic problem in reply to Ken C., 12-08-2004 20:24:22
I envy you for living there. My heart's there even though I live in NC.
Bob M
12-08-2004 19:17:25
Just checking: You certain the Liftall lever (sticks out of the right side of the hydraulic reservoir) is pulled all the way back and latched? You'll get no flow through the remote 4 way valve if it is not!
Alaskapete
12-09-2004 04:21:10
 Re: SMTA hydraulic problem in reply to Bob M, 12-08-2004 19:17:25
Yes, the lever on the tank is pulled all the way back. It appears that handle from the valve is unattached to the valve. Thanks for the response.
