What all did MW make for the farmalls?
M Guy
12-09-2004 04:25:54
I have been wondering what all did M&W make for farmalls?I know of pto kits,overdrive,live hyd,pistons,cranks,throttles,But there had to be more right?
Thanks,
Will
r4etired
12-09-2004 16:06:54
 Re: What all did MW make for the farmalls? in reply to M Guy, 12-09-2004 04:25:54
They also made a 9 speed, dual carb intake manifold, dual carburators. mounted so the throttle shaft ran straight thru the first carb to the second then to the original govenor linkage. Gordon Rice had a few of these a few years ago.
ej
12-09-2004 12:31:17
.Dual hubs,rocker arms for valve train.
captaink
12-09-2004 07:38:55
M & W also made a "Super Snoot" for tractors (many brands) under a mounted corn picker. The function was to close the area that air was pulled in by the radiator fan, and move it up above the picker to eliminate husks and silks from plugging the radiator.
Bob M
12-09-2004 05:31:28
Will - Add to your list high performance governors, also high torque starters and 12 volt conversions - to better spin engines equipped with M&W high compression pistons.
M&W also offered turbocharger kits, manifolds, oversized oil pans, etc for later generation IHC and Deere diesels.
