Farmall H, My Dist. rebuild from last night?
Tanner Clark
12-09-2004 04:34:28
Ok. I was able to rebuild the Dist. this evening. When I took it apart I noticed the coil, it was a 6-Volt coil. Ok so here was the original setup that came with it. Apparently it had a 12 volt battery, a 6-volt starter motor, 6 volt coil, dist. and an alternator. I am confused now, as to what set up he had, and or what type I should set up. I will run a 12 volt set-up, but I am curious about the altenator, and if the 6 volt coil set -up could have hurt it in anyway. O ya, Can I run the 6-volt lights that I have on the tractor with the 12 volt set up, minus the resistor., or can I just change out the bulbs into a 12 volt setup somehow??
Bob M
12-09-2004 05:15:18
 Re: Farmall H, My Dist. rebuild from last night? in reply to Tanner Clark, 12-09-2004 04:34:28
The setup you’ve got is very common. So long as there’s a ballast resistor is wired in series with the coil primary (to limit voltage seen by the coil to 6 volts) it’ll work fine. All the other electrical components (including the starter) are OK on 12 volts except for the lights.
For the lights simply swap 12 volt bulbs into the existing lamp assemblies. Standard automotive single filament brake/backup bulbs (#1156 lamps) fit and work great. (Alternatively you can mess around with series resistors and operate the existing 6 volt lamps on 12 volts, but it’s a PITA...I don't recommend it!)
