Wiring diagrham for converting MTAD to eletronic i
Duanes
12-09-2004 14:14:16
Need wiriing diagrahm for converting MTAD to electronic ignition. I assume MD or WD6 would be same. Thanks.
Novel Idea Guy
12-09-2004 18:38:35
 Re: Wiring diagrham for converting MTAD to eletron in reply to Duanes, 12-09-2004 14:14:16
Follow the instructions that come with the kit. All electronic ignition is, is a little gadget that replaces the points and condensor. If you can figure out where to install it, you can figure out how to wire it.
Duanes
12-10-2004 06:13:11
 Re: Wiring diagrham for converting MTAD to eletron in reply to Novel Idea Guy, 12-09-2004 18:38:35
If, I had the wiring diagram that suppose to come with the kit I wuold not be asking Einsteins!
Geoff NY
12-09-2004 15:57:32
Why on earth would you want to? It only runs on gas about 2 minutes a day and most of us run "em about 2 days a month. Seems like a really pricey setup to me, but it"s your money. Stick "em in as per the manufacturers instructions. The fact that the distributer turns in the opposite direction shouldn"t hurt. Your wiring from the manifold will still cut power when you switch over.
