Farmall F-20 Manufactuer date
JK67
12-10-2004 14:15:26
I have a Farmall F-20 that has been repainted. The serial number tag had been removed when I bought it. Is there any other way to tell what year it is?
JD @ Antique Acres
12-10-2004 15:04:13
 Re: Farmall F-20 Manufactuer date in reply to JK67, 12-10-2004 14:15:26
Serial Number should also be stamped on the block. I am unsure which side it would be on the F 20
pg
12-10-2004 15:32:23
 Re: Farmall F-20 Manufactuer date in reply to JD @ Antique Acres, 12-10-2004 15:04:13
look on the carb side of the frame. should be stamped on top side of rail. pg
SproutW
12-12-2004 02:51:49
 Re: Farmall F-20 Manufactuer date in reply to pg, 12-10-2004 15:32:23
Just like pg stated, look on the carb side (If you are sitting on the tractor it would be your left). The F-20's have three serial numbers on them if everything is still original. The number plate on the tool box (you stated it was missing). The frame rail on the carb side, located next to the rear mount where the engine bolts to the frame. Finally, the rear part of the engine just below the head will have the serial number stamped on it. The serial number from the engine may be different from the frame if the engine was replaced by another tractor earlier in it's life. Hope this helps.
