Aftermarket 3 point for 300 farmall
woodrow
12-11-2004 05:10:36
I was told by a friend that he found an aftermarket add-on a couple of months ago on ydt site that came with a draw bar assembly made into it. It bolted to the rear and had 2 cylinders with it. The drawbar was removeable. You simply removed the factory U and all this assembly bolted back in factory holes. Does any one know the company that makes one?
Farmall Don
12-11-2004 08:09:39
 Re: Aftermarket 3 point for 300 farmall in reply to woodrow, 12-11-2004 05:10:36
I have one on my M. Its the cats you know what. I can blade the driveway and cut grass with a 3pt finishing mower.
Allan in NE
12-11-2004 05:24:11
Here ya go.
Allan
third party image
woodrow
12-11-2004 06:07:05
 Re: Aftermarket 3 point for 300 farmall in reply to Allan in NE, 12-11-2004 05:24:11
Looks like what was described to me but it was my understandin that it didn't use the original Farmall horseshoe. Do you sell the product in the picture or know how to contact the manfacturer.
CNKS
12-11-2004 09:28:29
 Re: Aftermarket 3 point for 300 farmall in reply to woodrow, 12-11-2004 06:07:05
Allan and 26Red are correct and are showing pictures of a Saginaw -- the best one made. Steel Wheel Ranch also sells one that comes with it's own U drawbar, a disadvantage is that you can't use the swinging part with their drawbar. I think is is a Cross (not the Cross hyd cylinder company). I believe the Cross has only one cylinder, though.
26Red
12-11-2004 09:13:52
third party image
I have the saginaw unit on my 300 it is the best one out there for the money.
Kelly C
12-11-2004 15:25:48
 Re: Aftermarket 3 point for 300 farmall in reply to 26Red, 12-11-2004 09:13:52
third party image
I would agree the Saginaw is the best.
I have a cheapie 3pt on my 460. Its has a draw bar that you can remove. I wouldnt want to do nay heavy pulling with it, would just rip out of the 3pt unit. Pulled my baler with it and that works, Not going to be plowing with it though.
Allan in NE
12-11-2004 06:15:56
Woodrow,
The link to the company that builds these things is at the bottom of my last post.
Hope this helps,
Allan
