Gov. Adjustment
T Quick
12-11-2004 08:29:55
Restoring 2444 lo-boy. need help adj. the governor.
REA
12-12-2004 14:55:36
 Re: Gov. Adjustment in reply to T Quick, 12-11-2004 08:29:55
Hi T Quick,
* Take out any looseness, place throttle rod all the way fordward, pull pin from linkage that connects governor arm to the throttle rod. Hold both the throttle rod and the governor lever all the way back, then adjust the linkage so that the pin slips straight back into the linkage, then tighten assembly back together. Recheck low idle.
Hope this helps.
Bob
REA
12-12-2004 14:36:21
Hi T Quick,
I did have the instructions to set the governor system up. From memory this may not be precise, but believe that you have to have the governor lever fully towards the carburetor (tractor not running)adjust the linkage place assembly back together. When I locate the instructions I'll give you a return message. May be someone else has a comment?
To be on the safe side make a mark on the leakage, so you can return to it if my memory is missing something. Hope this helps.
Bob
