Neuss 239D
Ian Davies
12-11-2004 16:16:45
Got a little querry here
WHat is the difference between a D239 and a DT239 engine? The link below shows all the different engines made at the Neuss plant. I see the DT version makes more horsepower would a DT239 kit(sleeves pistons) fit a standard D239 engine. I Need to repair engine so may as well get as much power as possible. Any help appreciated
http://homepages.compuserve.de/matbush1710/z_english/e_engine.htm
JB2
12-11-2004 18:17:43
 Re: Neuss 239D in reply to Ian Davies, 12-11-2004 16:16:45
Hi, the DT239 had a turbo on it and was used on the German build 856XL@85HP. Don't know if it had additional oil cooler and lager rad.
You can easily get 70 HP out of a standard D239 just by adjusting the injector pump.
JB2
