Need injector pump help on 460. Please?
Rickyp
12-11-2004 18:30:55
I bought a 460 that has been sitting. THe pump was rebuilt and installed 2 years ago and has sat for those two years. I have fresh fuel to the inlet line that goes in the pump. For some reason I am not getting any fuel to the injectors. I have all the air out up to the pump. What do I need to do? I had to take the pump off to get it to static timing. I took a screw driver and stuck in side it to rotate the pump. It was off 180 degrees. Any help will be greatly appreciated. Thanks, Ricky
