Aw.............!!!
Allan in NE
12-13-2004 03:41:44
Hi All,
'Taint this one purdy!! Darn things are just plain hard to find anymore! :>)
Allan
third party image
kfox
12-13-2004 14:30:16
 Re: Aw.............!!! in reply to Allan in NE, 12-13-2004 03:41:44
The local paper has a sale listed for tomorrow with a IH Air planter listed, but I don't know if it's what your looking for. Check out the sale on 12-14 Latham on this link...
ken
http://www.bostoncentury.com/
Nebraska Cowman
12-13-2004 05:19:09
nice one Allan
Farmall Ed
12-13-2004 04:52:53
Allan, For the benefit of an old hills of Tn farm boy,what is it? Thanks Ed
Allan in NE
12-13-2004 05:01:09
 Re: Aw.............!!! in reply to Farmall Ed, 12-13-2004 04:52:53
Mornin' Ed,
It is a 3-point IH Cyclo 500 air planter.
I'm trying to find one in a 6-30" row version. The narrow versions didn't have the "dolly-trail" or lift-assist wheels.
This is the air planter that everyone under the sun cussed and hated. But if they are set up correctly, they work sooooo sweet and you can plant just about as fast as you can drive a straight row. :>)
Thanks for the hollar,
Allan
SuperCmore
12-13-2004 07:13:20
 Re: Aw.............!!! in reply to Allan in NE, 12-13-2004 05:01:09
Allen, I never got to really plant corn or beans...that was always the elder's or my fathers job. Few years ago, I was down at my farm in Missouri, and my cousin, who was probably 57 or 58 was planting, while his 83 year old father was sitting in the fill truck. My cousin stopped at end to fill, I climbed up on the ole 1206 and said "how come your planting, and not your dad??" He replied, "because this is MY new Cyclo 8 row narrow corn planter". To my knowledge, it was the first time he ever got to plant....and he was almost 60 at the time!! Sound familiar to anyone?? I might have planted a few rounds while dad ran back to house...but not much. The younger generation couldn't make the rows straight enough to suit I guess....Thanks, Cmore
Hugh MacKay
12-13-2004 08:18:40
 Re: Aw.............!!! in reply to SuperCmore, 12-13-2004 07:13:20
Cmore: Got to plant my first corn with a new cyclo at 33 years of age in 1975. I had planted corn for about 6 years before that with an older unit. That was precisely why I got to plant corn at a young age, I could make straight rows.
I had a young lad with farm background working for me. His father was an excellent tractor operator. This young man was a good worker and for the most part a good tractor operator. I tried everything imagionable to get that young man to plant corn in straight rows. That fall he went to University, some 120 miles away, met a young lady, so he wanted to find a summer job near where he was at. He phoned one night, advised he was sending a resume to an aquaintance of mine, could he use my name as reference. I advised he could do that, but questioned what might happen if Mr. P asked if he could plant straight rows. I was at a grain producers meeting some 2 weeks later and yes, Mr P did ask.
He got the job, and his first asignment was plant 800 acres of corn with a 966, 6 row cyclo and chemical saddle tanks on tractor doing herbacide at same time. He did plant corn in straight rows finally. I guess my 656 with 4 row cyclo and no spraying equipment didn't chalange him enough.
Allan in NE
12-13-2004 08:28:48
 Re: Aw.............!!! in reply to Hugh MacKay, 12-13-2004 08:18:40
Hi Hugh,
'Course we farm on the flat where things are oftentimes done a bit differently, but I've found that the biggest thing that guys do wrong in both planting and cultivating is to have their hitch locked up rigid instead of letting it "sway". If it is left rigid, every little 'wiggle' is transmitted back to the implement.
Also, ‘trying too hard’ can contribute to the crooked rows. :>)
Allan
Hugh MacKay
12-13-2004 09:37:10
 Re: Aw.............!!! in reply to Allan in NE, 12-13-2004 08:28:48
Allan: I always used pull type equipment, only mounted gear I had was a semi-mount plow and a spray unit on my 656. I had the boom mounted out front, with electric controls. Two tanks, 200 gal 3 point and a 500 gal wagon mount. Wagon tank had circulation and discharge only for supplying 3 point tank. I could drop it for filling at any time as well as doing small areas.
Biggest mistake I've seen guys make trying to make straight rows, is setting their markers for running front tire on the marker line. Look right down the radiator cap and center line will make the job a whole lot easier. I had a couple of fields followed curve in a highway. Most guys had trouble keeping row spacing right on that curve. It was a case of may as well follow the curve as river on other side of field had almost the same curve. Try and make straight rows in that situation, and one will waste a lot of time planting, spraying and harvesting.
Jimmy King
12-13-2004 10:53:19
 Re: Aw.............!!! in reply to Hugh MacKay, 12-13-2004 09:37:10
You are right Hugh I found out at an early age to use the radiator cap and a fence post and never look back.
Allan in NE
12-13-2004 09:52:42
Hi Hugh,
Yeah, I hear ya. Also, different parts of the world use diffferent methods.
I think we stopped using anything but wide fronts clear back in '54-'55 or so.
Also, our fields are smaller and I like the mounted equipment to make for a shorter headland (just made the flood irrigation work better). Prior to the advent of the circles, fields around here were always less than 100 acres.
I've seen some of the fields you guys work up in the north country; 600 acres at a pop! :>)
Allan
Migraine
12-13-2004 09:05:41
We had a 4 row cyclo wide planter and later a 6 row narrow. If you used medium sized corn seed or bigger (if you could talk dad and gramps into spending the few extra bucks for the big rounds) that cyclo would do just fine, On soybeans , I think we planted at about 6 or 7 miles per hour. We had the pull type but kept the hitch as short as possible. Single rear on the tractor planting with an 856 with a tight little turbo. Sweet whistle all day and half the night. I one night started on 80 acres at 10 p.m. with gentle contour In our area, how good a farmer you were was measued by the straight half or mile long rows. I sat on the front edge of the seat all night long and worked my way sometimes several feet upside the markerto keep those rows straight. Had to wait till sunup to see how I did. Gramps said "Not Bad Kid". That was good enough for me. He did go up in a small plane to check it out later in the season and said it passed inspection. Wow that was pressure. Migraine
captaink
12-13-2004 08:57:54
Amen to trying to hard. When I planted I quit worrying about getting the rows straight (I was in my mid 30’s) because I always figured that since the shortest distance between two points was a straight line, a crooked row had more plants in it! :>) Had several neighbors comment on my straight rows and asked how I did it. I told them I didn’t really try, I wasn’t worried about getting them straight (since my cultivator had been replaced with a sprayer) so I just relaxed, pointed the tractor down the field and drove. Sounds simple doesn’t it?
F-Dean
12-13-2004 10:42:27
 Re: Aw.............!!! in reply to captaink, 12-13-2004 08:57:54
Remember that you can grow more corn in a crooked row!!!
