rpm of Farmall Super C PTO Pulley?
Dail Howard
12-13-2004 09:53:08
Can someone tell me the rpm's that the PTO Belt Pulley turns when the implement PTO is turning at approximately 540 rpm?
El Toro
12-14-2004 06:32:22
 Re: rpm of Farmall Super C PTO Pulley? in reply to Dail Howard, 12-13-2004 09:53:08
Hi Dail, My old IH manual list's the governed speed of the C and Super C at 1875rpm's instead
of 1815rpm's. Not sure which is correct.
You can buy a hand tach and just hold
it against the center of the pulley when doing belt work with the tractor. You're between 1363 and 1400 rpm's. Hal
El Toro
12-13-2004 11:25:10
I came up with 1363rpm's too. Hal
GeorgeH
12-13-2004 11:15:46
My operators book shows following specs for pulley:
8.5 in diam, speed 1,363 rpm gives 3033 ft per minute belt speed.
7.5 in diam, speed 1,363rom gives 2760 ft per minute belt speed.
These numbers assume pto speed of 539 rpm attained at maximum governed speed (full load).
gene b
12-13-2004 10:48:09
The shaft runs around 1200-1400 this will be approx can vary if your gov is set to correct engine rpm at high throttle.
