Farmall H 1945
Connally Fulp
12-14-2004 10:21:21
Have bad hydraulic leak under pump. Gets worse longer it is used. Using 30W non-detergent as specified. Problem caused by gasket or pump wearing out?
Paul in Mich
12-14-2004 10:54:52
 Re: Farmall H 1945 in reply to Connally Fulp, 12-14-2004 10:21:21
Most likely, it is neither gaskets or worn out pump, but rather bad seals. Remove the pump, and replace the seals, and the leaking should subside.
williamf
12-14-2004 13:11:50
 Re: Farmall H 1945 in reply to Paul in Mich, 12-14-2004 10:54:52
Also, could be around where one of the three outlet pipes screws into the unit. They've got pressure on them, the shaft seal doesn't. Try taking each one out, put a little teflon tape on the threads, screw it back in tight. That's something you can try without taking the pump down.
There's a story about this one, too.
Wm
