super a factory with no hydraulics?
ronnnnneee
12-15-2004 00:02:14
did all super a's have hydraulics?i have a super a with none could it have come that way from the factory?
cheinzle
12-15-2004 11:58:17
 super hydraulic specs in reply to ronnnnneee, 12-15-2004 00:02:14
anyone know what the flow rate / pressure specs for the Super M hyd pump are?
gene b
12-15-2004 05:33:13
 Re: super a factory with no hydraulics? in reply to ronnnnneee, 12-15-2004 00:02:14
Are you sure you have a SUPER A or a repaint job with SA decals as there are lots of tractors out there with wrong decals. And yes you could order a SA without hy set-up. I seen one some where at a show. Tractors could be ordered with out lots of extras like pto,belt pulley,ta,fast hitch and so on.
Red Dave
12-15-2004 05:24:20
I've seen Super A blocks used as replacements in A's, are you sure there hasn't been some parts swapping?
Jim Becker
12-15-2004 05:09:19
Could have come without, but would have been unusual. Probably more likely to be a frankentractor.
Hugh MacKay
12-15-2004 02:34:27
I don't think you will get a lot of responce on that statment unless you tell us serial number and casting code dates of all major castings.
Couple of other items you might tell us are, does engine block have hole for mounting pump just under distributor. Also is the top of torque tube flat or round.
Super A
12-15-2004 05:47:24
 Re: super a factory with no hydraulics? in reply to Hugh MacKay, 12-15-2004 02:34:27
I have seen one (1) Super A without hydraulics. It was in a salvage yard, had a lot of parts robbed but it was for sure a Super A. The number was in the 250,xxx range so it was a fairly early one. Technically Touch Control was an option. I would bet though that 90% of them had it however. Please post the serial numbers and casting codes!
Al
