M power
Steve M
12-15-2004 12:16:31
O.K. call me crazy. If I push out the piston sleeves on my M, I have a bore of 4 1/8". Why can't I shove a 4 1/8" piston in there without a sleeve and have the cubic inches a 450 has ?? Seems to me other than maybe some honing the bore has to be as straight as the sleeve. How foolish a thought is this ?? Is the block not hard enough ??
Jim J
12-16-2004 16:56:16
 Re: M power in reply to Steve M, 12-15-2004 12:16:31
I can get you the pistons.
Scooby
12-18-2004 11:48:05
 Re: M power in reply to Jim J, 12-16-2004 16:56:16
Jim J, where can he get them he is thinking that he wants to try it...Scoob
ChadS
12-15-2004 12:26:08
you can just hone the block, and it is 4-1/8 all ready. use the 450 head gasket. Only problem is the small pinned pistons, onthe big M rod. Make a brass bushing to adapt the wrist pins to the rods,, I make them, so its not hard to do. ChadS
Stan(VA).
12-15-2004 14:05:01
 Re: M power in reply to ChadS, 12-15-2004 12:26:08
When I put an aftermarket 4-1/8" overbore piston and sleeve kit in my Super M, it already had the larger piston pins. Fit right on the SM rods, but the IH P&S set that a prev owner had installed did use the extra bushings.
Stan(VA).
ChadS
12-15-2004 15:12:36
 Re: M power in reply to Stan(VA)., 12-15-2004 14:05:01
Yep super Ms had the big pin too, , Steve!! Get r done! LOL ChadS
Steve M
12-16-2004 12:47:56
 Re: M power in reply to ChadS, 12-15-2004 15:12:36
Thanks guys !!Don't know where I can get 4 1/8" domed pistons (only) do you ??
