3pt hitch ignorance...
Phil from MD
12-15-2004 12:48:45
I have an IH 404 and a blade and plan to plow snow this winter with it. They way my three point hitch works it does not allow it to "float" over varying height ground rather it seems to want to stay fixed in the position you move it to.
How or what do I need to do to make it "float" so that it will not tear into my blacktop?
Yes, I know I am ignorant when it comes to it's use. I have read the owners manual and I cannot find it refering to floating the 3 pt or leaving it down so it can change height by itself.
Thanks
Aces
12-15-2004 15:44:22
 Re: 3pt hitch ignorance... in reply to Phil from MD, 12-15-2004 12:48:45
Phil I don't remember just what the 404 and 504 had for hitch but if is a true 3 point it will float because all 3 points float. Only yjr old fast hitches had down pressure.
Hugh MacKay
12-16-2004 02:31:48
 Re: 3pt hitch ignorance... in reply to Aces, 12-15-2004 15:44:22
Aces: Your right, 404 and 504 have the new type rockshaft with internal lift cylinder. Just looked at it in the IT manual. From the description I can't see how Phil is getting double action.
Could it be that his 404 came from factory with no 3 point, and his hitch is an aftermarket hooked into a double action control valve with double action cylinders. The IT manual doesn't say but the valve looks same as those used on 504, 656, etc. in which case it would have a float position if lever were pushed further in the down position.
catmandoo
12-15-2004 14:11:59
well on my 460 there is 3 valve that set right in front of the shifter,you can put a 9/16 wrench on them and turnlike 1/4 turn if i remember right this is how to change it to float,but as for which one to turn i can't help ya there.
CNKS
12-16-2004 18:39:28
 Re: 3pt hitch ignorance... in reply to catmandoo, 12-15-2004 14:11:59
I believe those are for the remotes, not the 3 point.
steveormary
12-16-2004 09:47:43
Phil
The fast hitch on my 706 would float. I was told that there was some way to get down pressure on the fast hitch.
steveormary
jdiho
01-29-2005 21:38:19
 Re: 3pt hitch ignorance... in reply to steveormary, 12-16-2004 09:47:43
There is a pin (about 5/8") just below the lift cylinder that is removed to make the 2 ph float.
