300U Reservoir Cap
PAULIH300
12-15-2004 15:22:59
My 300 Utility has a weld on the hydraulic tank plug.I imagine somebody welded up the vent hole.I dont know why they would do that....unless fluid sprayed out of it when they overfilled it,or it kept the leaks at a minimum (created a suction so fluid couldnt leak out when sitting?).Also,the seat track seems to screw right thru the tank....could this cause a source of leakage(when the tank is full)?
Bill46
12-16-2004 09:09:39
 Re: 300U Reservoir Cap in reply to PAULIH300, 12-15-2004 15:22:59
I have 3 300U and 2 350U tractors. They all have the dipstick. Is there a chance yours got broken off?
TDK
12-16-2004 07:59:09
The weld on the filler plug is on all of them, don't know why. The breather for the system is in the middle of reservoir, just behind filler plug. It's either a 3" cap with vent holes in it or a small filter about 1" diameter.
Old one
12-16-2004 07:55:32
My 300U has a threaded pipe plug on the front very close to where the outgo/return lines come into the reservior, which is the full level. With the plug out the fluid runs out when full.
Kerwin
12-15-2004 16:28:36
Is the weld on the cap there to hold in the dipstick (which is part of the cap unit)? The vent hole on a 300U is located elsewhere on the lid. Also, the fluid level shouldn't be high enough to cause a leak through the seat mounting bolts if they go all the way through. I've had the lid on mine off and can't remember how deep they were. Hope this helps.
PAULIH300
12-15-2004 16:37:35
 Re: 300U Reservoir Cap in reply to Kerwin, 12-15-2004 16:28:36
Well,I overfilled the reservoir.....its tough to see how much you have in it when the funnel is stuck in the hole. lol
The cover is actually a square headed pipe plug on mine,with a dipstick inside.I'm wondering if thats original.With everything else on this one,its been cobbed for way too long....I aim to straighten this thing out....eventually.
Kerwin
12-16-2004 19:09:44
 Re: 300U Reservoir Cap in reply to PAULIH300, 12-15-2004 16:37:35
Your description of the filler plug and description matches mine, which I'm pretty sure is probably original. If you haven't already done so, get a operator's, parts and service manual for the 300U. The parts book is good to figure out what is original, and what has been added/modified at a later date. Binder books is a good source for quality reprints.
PAULIH300
12-16-2004 19:12:16
 Re: 300U Reservoir Cap in reply to Kerwin, 12-16-2004 19:09:44
Books are on order....
The mail service just isnt fast enough though!
