1066 ???
PJB
12-16-2004 05:00:59
A friend of mine has a 1066 that acts likes it's locked in two gears at onces. You put it in gear and let the clucth out and it stalls. Could it be the linkage ???
MTK
12-16-2004 06:39:10
 Re: 1066 ??? in reply to PJB, 12-16-2004 05:00:59
I bet it's the linkage,as mentioned by Dph.We have
had this happen on ours,check the lower linkage on
the console at the transmission deck level.It is probably hung in between the two gears,like he said.You should be able to nudge it over either
way,with a decent size screwdriver.
ash
12-17-2004 10:50:23
 Re: 1066 ??? in reply to MTK, 12-16-2004 06:39:10
yes, its definatly the linkage..if its set up like my 1086 you have to take off the seat and the two panels wre your feet are, and move the range lever into neutral while some ones rocking the tractor..i believe its the lever closest to the left if your sittin on the stearing wheel
dph
12-16-2004 05:11:41
It's locked in two gears, probably low and reverse. Rev it up really high and... NO, just kidding. :) Don't do that. You should be able to pry the reverse linkage ahead at the shift console. If it is ahead, and the shift lever lines up with all sides in neautral, then the problem is lower. Keep following the linkages down. I don't think it is likely, but you might have to pull the tranny top. If so, not a bad job. Let us know how you turn out.
