Super M Knock in Trans.
DJ
12-16-2004 19:09:59
The noise happens in nuetral when clutch is engaged. its not in the egine fresh overhaul. if that gear has a tooth missing where could i pick up a new gear. dealer cant get them anymore.
Kelly C
12-17-2004 07:01:15
 Re: Super M Knock in Trans. in reply to DJ, 12-16-2004 19:09:59
third party image
If you want to look at the gears. Just pull the belt pulley unit.
You can see all the tranny gears in the opening.
thats how I found the chipped gears on my 400. Same trans as a SM.
I am also susspecting the bearing on the end of the input shaft. I could see that one knocking around if out.
williamf
12-17-2004 05:22:42
wtw@weberstractorworks.com
You could email these guys. Or call them at (507) 434-0876.
Wm
Bob Frey
12-16-2004 20:16:17
Any chance it's the belly pump? You can take the coupling out and see if the sound stops.
Bob
DJ
12-16-2004 20:55:08
 Re: Super M Knock in Trans. in reply to Bob Frey, 12-16-2004 20:16:17
It has live hydralics no belly pump.
