Farmall H and M values??????
Paul in WI
12-17-2004 11:50:57
I was informed by an elderly lady she has two tractors she would like to sell. A Farmall H and a Farmall M. Neither tractor has been run since 1991, when her husband died, but they are stored in a shed. The general condition looks ok but would still require alot of work to make them look nice. What would be a fair price to offer her for these? I guess I would be concerned about the engines being seized up and/or dry rotted gaskets leaking and costing me alot of money to replace. Will also need carbs overhauled. I have no idea what kind of money it is going to take to replace gaskets and overhaul carbs so I am unsure of what to offer. Thank you..... .
RN
12-17-2004 15:53:05
 Re: Farmall H and M values?????? in reply to Paul in WI, 12-17-2004 11:50:57
$500.00 for pair as salvage/scrap, $1000.00 as parts/restores. Price up depending on tires, engine turnovers and compression checks. What are running tractors bringing locally? $1000.00 to 1500.00 for fair usable Hs and maybe $2000.00 for Ms? Restored prices anybody Guess? Younger brother got H for about $800.00, replace battery and drive away, used back tires $100.00 each, dist tuneup parts and plugs about another $40.00. Engine oil and filter, drain some water out of transmission and fill- about another $40.00. Using on wood saw couple months back, smokes a little at start. This in Iowa couple years ago. RN
El Toro
12-17-2004 12:21:41
Hi Paul, I would try and see if you can turn those engines over to see if they're seized. Then if they're free, you can make her an offer.
Hal
Allan in NE
12-17-2004 11:57:03
Hey Paul!,
Just my opinion, but I'd say $2700 to $3200 for the pair if they ran in '91 and the husband was using them to farm with.
Chances are you can go out there and they'll both pop right off.
Who knows?
Allan
