Cranks on H and M
Charlie M
12-17-2004 16:15:47
Anybody know if there was an offical place to store the crank for a H and M.I store mine in the tool box on each tractor as there are occassions where I use them.Seems like IH would have had a place intended for them.
PUTTER
12-18-2004 11:38:31
 Re: Cranks on H and M in reply to Charlie M, 12-17-2004 16:15:47
We always kept ours in the square tubing thats part of the drawbar hardware. PUTTER
jonesy
12-18-2004 05:10:54
Ive got a Super H that has a designated factory clip bracket on the transmission cap.
Redmud
12-18-2004 04:30:39
The crank on my 42 H is attached permanent with a roll pin. I know it didn't come this way, it was this way when I stole the tractor. I like it, don't have to worry about my crank now.
captaink
12-17-2004 20:07:33
I put mine on the transmission cover with the front between the steering post and the gear shift lever.
Sloroll
12-17-2004 19:55:24
With the early easy ride seat I always put the cranck end between the platform and the bottom of the seat base and the handle upward in the seats channeled rearshock support.
ejr
12-17-2004 16:33:38
We allways put them between the engine block and frame rail on the right hand side sitting in the seat.
Kak
12-17-2004 18:24:56
 Re: Cranks on H and M in reply to ejr, 12-17-2004 16:33:38
Yes, our was always between the engine block and the frame of the engine. Don't know if that was the recommended by IH spot for it but it sure is a handy place for it if you don't have electric start.
