IH 464 gas, rough runner at low RPM
Jay Kinder
12-17-2004 17:30:31
I have a 1974 IH 464 gas that runs rough at Idle and low RPM.It runs fine under a load and at higher RPMs.I have installed new plugs,wires,distributor cap and rotor. I have also cleaned the carb and installed a new air filter. I did not put any new parts in the carb.I was told that it could be a burned valve but I want to make sure it is not a carb. issue before going any further. Any suggestions, Thanks in advance.
Allan in NE
12-17-2004 18:02:36
 Re: IH 464 gas, rough runner at low RPM in reply to Jay Kinder, 12-17-2004 17:30:31
Jay,
If you are absolutely sure it is A-Okay at off idle and under pull (these things can sometimes fool ya), here's some ideas.
I'd really check for a vacuum leak at the intake manifold or carb base area. Also, are you sure your idle circuit in the carburetor is okay and functioning?
Also, a high dwell setting could cause your headache.
A burnt valve won't cause a discriminate idle miss; a burnt valve will make it miss all the time. However, a valve guide that is wobbled out can & will cause this symptom and could make it miss only at idle.
Hope ya get 'er,
Allan
