To much fuel now?
Shaggy
12-18-2004 06:42:08
I redrilled the jet in the carb for my B because it was running very lean. I took it 2 sizes bigger and it run and idles great with no smoke. The only time it smokes is when I shift from 3rd to 4th and the governer is bringing things back up to speed. Oh this is at WOT. I am thinking its about right.
What about you guys?
CNKS
12-18-2004 13:42:00
 Re: To much fuel now? in reply to Shaggy, 12-18-2004 06:42:08
Whatever works -- but those engines usually run rich, not lean. I think you had something plugged and compensated for it with a larger jet. It should only give an occasional puff of smoke under acceleration.
Shaggy
12-18-2004 15:51:15
 Re: To much fuel now? in reply to CNKS, 12-18-2004 13:42:00
Well its not all stock. It has 3 1/8 High domes with a 140 head with a little port work done to it. (just a clean up)It has about 10 hours of run time and most of that is just messing around the Villiage I live in. Oh and the Carb was a fresh one too. But I will check it out to see if anything is plugged. thanks Shaggy
CNKS
12-18-2004 19:32:54
 Re: To much fuel now? in reply to Shaggy, 12-18-2004 15:51:15
If it runs ok, leave it alone, but you can tell if it is too rich by looking at the plugs.
