Got fuel
benred
12-18-2004 15:19:46
how do you ajust the amount of fuel in your carb. someone told me one reason a carb floods is if the fuel level is to high? help
CNKS
12-18-2004 19:20:01
 Re: Got fuel in reply to benred, 12-18-2004 15:19:46
More likely is that the float needle and seat are worn, or the float hangs up on the side of the carb, or that you are simply overchoking. Post what tractor it is and someone can give you the recommended float setting, which you can do after putting in a new needle and seat.
PAULIH300
12-18-2004 15:24:24
The fuel level in the carb is set by the float.You would need to remove and open it up to (bend) adjust it.
