Weight
PAULIH300
12-18-2004 18:53:20
Approximately,what does a "bare" 300U weigh? I read somewhere its around 4,000 lbs.
Hugh MacKay
12-19-2004 06:54:08
 Re: Weight in reply to PAULIH300, 12-18-2004 18:53:20
Paul: I'd have to go with CNKS and REDRIDER, don't think its possible to get 300U under 4,000 lbs. I never had a 300U but I know it doesn't take a lot more than calcium chloride and one set of weights to put a Farmall 300 over the 6,000 lb mark. On shipping weight I rather doubt the Farmall weight is a 1,000 lbs more.
sammy the RED
12-19-2004 01:11:29
My 1960 Guide says 3511 lbs. from the factory.
Redrider
12-18-2004 19:43:30
4300lbs must be stripped. I have a 1956 300U and it tips the scales at 4900lbs. Our 300 has 6 inch front rims with 6.50 X 16s on the front, 16.9 X 24s on the rear, 2 point, TA, Live PTO, 3 Valve hydratouch and power steering. So you see a 4300lb 300U must be just the basic tractor.
CNKS
12-19-2004 09:28:05
 Re: Weight in reply to Redrider, 12-18-2004 19:43:30
That's only a guess, as I don't have any accurate data -- easy to get 5000 lbs. I didn't know the 300U came with 24 inch rears, most had 28's.
CNKS
12-18-2004 19:09:19
Probably closer to 4300 lbs, Guy Fay's data book has a typo in it for the 300U. The 330U, which is a 300/350 with a smaller engine weighs about 4200.
Harold H
12-19-2004 16:05:31
 Re: Weight in reply to CNKS, 12-18-2004 19:09:19
My book says 3511# with standard equipment.
Harold H
CNKS
12-19-2004 18:23:38
 Re: Weight in reply to Harold H, 12-19-2004 16:05:31
Are you using some of the info you had when you were a dealer? If so your data is better than mine. Ken Updike's data book says 4800 for the 300U and 4000 for the 330U.
