WD6
Warren Opp
12-19-2004 08:08:36
I've been offered a WD6. Running condition,bad starter, just plan jane needs lots of work. Whats it worth?
Andy in Ohio
12-19-2004 10:54:48
 Re: WD6 in reply to Warren Opp, 12-19-2004 08:08:36
I purchased a SWD6 2 yrs ago in excellent mechanical cond., it started easily on gas and swiched over nice to diesel. Its a little tank when it comes to pulling things. tires were in good shape but mismatched, tin was fair but easily fixed. Has live hyd. that work well. It does have a patch under the rear end though. By running cond. does it need pull started to run? If it does run the other way unless you have a money tree in your yard or know a good diesel mech. thats cheap. I payed 1900.00 for mine if that gives you something to go by, probably about 500$ to much, but I certainly do enjoy using it. What are they asking for theirs out of curiousity? Good luck, Andy
David Manring
12-19-2004 09:46:13
Rubber and size of rear tires would be a big factor to me on price.
You see some listed up in Canada for $1500.00 to $3000.00 for a cherry one.
Parts are no problem(lots off M's fit) except for parts for the diesel engine.It will take some looking to find them.
