Carb. soaking questions??
john in Ct
12-19-2004 10:00:46
I am rebulding 2different carbs and I have a few questions about soaking them. Will Berrymans carb. soak hurt brass that I can't remove (riveted). On a different carb, will Berrymans hurt the metal on a Cub carb? Thanks!!
gusc
12-20-2004 15:21:45
 Re: Carb. soaking questions?? in reply to john in Ct, 12-19-2004 10:00:46
Been using Berrymans for years on all kinds of carbs with no problems.
I do follow the label instructions carefully though, I never leave anything in longer than it states-this stuff is potent.
The trouble with the carb cleaner that comes in a spray can is that it dissolves the gas gum but when the cleaner evaporates, very quickly, the gum is still there. Berrymans removes gum and it is gone for good.
I haven't used any other brands because Berrymans works so well I never had any reason to change.
I have nothing to do with Berrymans, don't even know offhand who makes it.
Andy in Ohio
12-19-2004 18:03:13
Ive never used Berrymans, but if its made for soaking carbs you should be fine. If you are still concerned, use regular carb cleaner from Napa. Ive soaked them overnight with no problems. Good luck
