B250 steering box
oldtime
12-19-2004 18:17:30
i beleave thay make a tractor in india that is the same does the steering box fit ? any ideas thanks oldtime
parts man
12-20-2004 15:28:36
 Re: B250 steering box in reply to oldtime, 12-19-2004 18:17:30
There wer 2 different steering boxes on the B250, a 1 arm and a 2 arm, you have to make sure to get the right one. If it"s 1 arm, the box from a B275 or B414 is the same. The Mahindra company still builds a knock-off of the B414. I"m not sure of the model#.
Michael Soldan
12-19-2004 20:27:44
Oldtime, I know that Steve at Ontario Used Tractor Parts wrecked a B250 this fall and likely has the steering box..(519)523-4922 and he will ship UPS..I don't know where you are but that might be the quickest fix. I believe a B275 and a 414 would likely be the same steering box but you would need to check this out..good luck..I have a B250...Mike in Exeter Ontario
