Bitin' My Tounge
Allan in NE
12-20-2004 13:43:07
Hummmmm.
I've got this "Red Mech" who to my mind is just an absolute 'monster' IH mechanic. Been at it all of his 70 years.
Okay, I watch him test the rear hydraulic pump on my 966. He tells me that it is just so-so and a little weak, 'cause it is only putting out 1800 psi at idle and he says it should be 2250psi.
I stood there and watched him test it.
So, I'm readin' in my IT manual this morning and according to it, he was actually doing a flow and pump pressure test instead of the "system relief pressure" test.
IT manual says it should run 1800psi & 10gpm @ 2400rpm and should be taken at one of the remote ports (which is exactly where he was at).
The manual goes further to say that the relief pressure test should measure 2000psi on the 966 (2250psi on the larger tractors), but is taken at the port right on the face of the pump body itself and that the hitch lever should be set past 'full up' to insure a "full and constant system pressure".
He obviously read the manual wrong.
Just keep my mouth shut? I don't wanna "correct" this guy, 'cause he really is good.
Allan
K.B.-826
12-21-2004 18:22:00
 Re: Bitin' My Tounge in reply to Allan in NE, 12-20-2004 13:43:07
Allan, nothing wrong with plugging the flow-rater into the couplers. Here's the way I learned to do it-
1- Run the engine at about 1500 RPM, tie the remote on demand, and turn the knob to restrict the pressure until it shows about 1200 psi, and at the same time, make sure that the flow guage shows flow. The pressure builds heat to warm the oil, but you don't want too much pressure right now, or you won't get enough circulation to get the system good and warm. Once the oil gets to 120 degrees, back out the restriction knob to 0 psi, run the engine up to rated speed, which would be 2600 RPM on your Black Stripe 966.
2- Check the flow guage- it should show around 12 gpm, mabey a little more, but not much less. This is called "free flow"
3- Now crank that restriction knob down and get as much pressure as you can. This could be anywhere from 1800-2500, because there are about four different relief valves that will fit your 9. At this point, you will have zero GPM flow.
4- Now back your pressure off about 250 psi from your maximum reading and check the flow guage. It should read at least 80% of your free flow.
If all of this checks out, you're good to go. If the max. pressure is low, the relief valve needs attention. If you don't have 80% of free flow at 250psi below max psi, the pump is shot. Hydraulic testing should never be done at low idle, since you've got a positive displacment pump, its output will be greatly effected by speed.
Randy SE-MN.
12-21-2004 05:52:32
Does this mechanic have an e-mail address??? Send him this thread, he might broaden his view of you.
1566 Jim
12-21-2004 05:51:57
Check with the mechanic - a lot of the flow meters has a pressure gauge in them and a restrictor valve so he can turn it down and check the relief pressure with the gauge hooked up to check the flow nad not have to hook other gauge into different port.
Dave (IL)
12-20-2004 19:13:58
I've only been hanging around her for a month and I don't know squat compared to you and some others, but you have convinced me over the last month that your shop knows how finicky you are, and how you want things to be perfect.
I don't think a good mechanic - as you say he is - would get upset if you said "I've been trying to follow along here and sumptin' musta got by me watching you do this test." I also can't see you sleeping well until you know for sure.
If you are a PITA, you certainly mask it well in your posts. :)
Hermit
12-20-2004 18:56:40
Take your manual to him and politely ask to look at his reference material so you can compare them together. A good mechanic will want to find out the real story.
Ron in Nebr
12-20-2004 16:47:14
Hi Allan, Two different courses of action come to mind here. One- do like the other posters said and figure out a nice friendly way to let him know that the test he did doesn't jive with your manual...maybe say something like "Hey, here's something interesting I'd like you to look at and give me your professional opinion on. This manual shows this and....etc... Maybe they printed the manual wrong? What do you think?" Otherwise, tell him that if the pump's still "so-so" that you'll go ahead and use it like it is for now since you don't plan to use it super-hard anyway. Good luck.
Allan in NE
12-20-2004 17:16:17
 Re: Bitin' My Tounge in reply to Ron in Nebr, 12-20-2004 16:47:14
Hi Ya Ron,
Yes, that's kinda how it went down and how we left it, so far anyway (just to let it go). But then, I also left them instructions that if they should find anything at all wrong with the tractor, don't bother calling, just repair it.
Reading this manual now has me wondering if maybe I'd better stop in there and have a little visit. :>)
By the way, saw your friend Scotty on Saturday night while I was working an anniversary dance. Had him up and he did a few; he does a pretty darned good job. Known him all these years and I had never heard him before. He says to tell you hi.
Allan
lee
12-20-2004 15:20:15
Just show him your manual and ask him to help you get this straight being that you are several cards short of a full deck.
Allan in NE
12-20-2004 15:27:10
 Re: Bitin' My Tounge in reply to lee, 12-20-2004 15:20:15
I think he already knows that I've got a lot of wheel slippage going on.
I notice he rubs his hands together and has a wicked gleam in his eye when I walk thru his door. :>)
Allan
lee
12-20-2004 15:49:26
 Re: Bitin' My Tounge in reply to Allan in NE, 12-20-2004 15:27:10
Well go in there with your manual and see who has more slippage, him or you. That would bug the crap out of me til I knew the test were done correctly. He won't be shy when he hands you your bill.
RustyFarmall
12-20-2004 14:28:21
Allan, I may stir up a bit of controversy here but I would double check the info in the IT manual before coming to any conclusions. I have never been overly impressed with those IT manuals.
Allan in NE
12-20-2004 14:40:50
 Re: Bitin' My Tounge in reply to RustyFarmall, 12-20-2004 14:28:21
Hi Rusty,
Never thought of that.
This one is the authentic IH "Blue Ribbon Service Manual".
I sure don't know; I'm about two thirds retarded as it is. :>)
Allan
captaink
12-20-2004 13:57:13
Allen,
Wrong is wrong and I would try to find a way to approach him about it. I would probably start by just asking him some subtle questions, like, “Is there a test that would show if I had a faulty relief valve?” That might spur enough interest that he would check the manual again. That might lead him to discover that he misread the manual, and he would do the test and be an even better mechanic in the future! You don’t come off as a smart aleck, and still accomplish your goal. My belief is that everybody, including life long mechanics, should be willing to both accept their errors and learn from them. That is what makes a good mechanic (or any other professional) what he is. You don’t need to be rude, crude, or anything other than maybe just inquisitive.
Just my thoughts…
Allan in NE
12-20-2004 14:08:59
 Re: Bitin' My Tounge in reply to captaink, 12-20-2004 13:57:13
Hi Captn'
Yes, it has already cost me a new Relief valve, 'cause we were trying to "fix it". Now he wants to pull that rear pump and "inspect the body".
Sounds to me like the pump is above the spec the way it is because it is pumping the 1800psi at idle instead of the called for 2400rpm. :>)
The only reason I hesitate saying anything is because he is such a nice man and he and his boys are so very through in their work otherwise. Just this one little mistake..... ..
Heck, I make a dozen mistakes before I pull my socks on in the morning. :>)
Allan
captaink
12-21-2004 06:33:34
 Re: Bitin' My Tounge in reply to Allan in NE, 12-20-2004 14:08:59
That's why I have a poster on the inside of my outside door to remind me if I have my pants on, my teeth in, my socks on, a matched pair of shoes, etc before I leave! :>}
LOL Have a good one!
Farmall Don
12-20-2004 16:17:11
I make a dozen mistakes by the time I get my socks on as well. It just seems someone is there to remind me of it and if everyone forgets, the wife is there to make sure Im reminded.
I would lightly bring it to his attention and play dumb. Its what I do and it easy and works well.
Andy Martin
12-20-2004 15:28:20
He's probably working from memory, not the manual, and is just confused with the larger tractors.
The advice to ask him to interpret the manual is the best and he will explain it, even if it is his error.
John M
12-20-2004 14:14:36
Just tell him not to worry about it.Its your money hes spending.
