leak
bad mechanic
12-20-2004 14:35:30
I pulled my M in the shop, the next day I noticed a puddle under the pto unit area. Seems like all I need to do is put in a new gasket. What should I expect when I pull the pto cover plate off? Will I flood the shop floor?
Herb In Tx
12-23-2004 11:08:40
 Re: leak in reply to bad mechanic, 12-20-2004 14:35:30
You will lose a considerable amount of oil. My thoughts are if the oil is clean and servicable then drain it from the rearend into a clean 1/2 oil drum and puter back in when finished. I may be all wet but I think my SH holds like 13 gallons. Herb
Glenn F.
12-20-2004 18:00:01
I think it's time to change your handle. A bad mechanic wouldn't even notice the leak or he would disreguard it if he did!
bad mechanic
12-21-2004 07:01:21
 Re: leak in reply to Glenn F., 12-20-2004 18:00:01
Yea, maybe I should change my handle. The truth is I don't know much about mechanican, but I keep trying. I usually dive into something, trying to figure it out as I go. Seems to be the way to learn. I just like to eliminate those major oil spills when I can. Thnaks for all in the input. I'll be back for more.
little john
12-20-2004 15:07:13
i was surprised when i pulled the pto off my
"h". i cleaned up a lotta' oil and decided to change the oil due to the spill. unless that tractor is really pointed downhill, some oil will pour out i think.
happy holidaze!
