Spin On Filters
PAULIH300
12-20-2004 19:01:26
Filter manufacturers list the 300 C169 as using both the drop in element and a spin on filter.Is there a way to convert to a spin on? Is there a kit offered? Would rather not add one of those remote mount bases...there are enough hoses with the loader attachment as it is,dont need any hanging off the engine too.
Brian Schmidt
12-21-2004 21:31:35
 Re: Spin On Filters in reply to PAULIH300, 12-20-2004 19:01:26
I have a kit I am going to sell if anyone is interested. Please contact me off this list if you are interested.
bermuda ken
12-21-2004 08:37:41
 Re: Spin On Filters- - - Here! in reply to PAULIH300, 12-20-2004 19:01:26
There is an online listing of the spin-on filters and the related kits for IH engines/tractors at:
www.cngco.com/oem.engine.html
PAULIH300
12-21-2004 17:10:13
 Re: Spin On Filters- - - Here! in reply to bermuda ken, 12-21-2004 08:37:41
Thanks,I ordered one up.Thats one easy way to "modernize" vintage machinery.The replacement WIX filter it is uses is 51051 which surprisingly is also listed under the 300 tractor applications along with the stock drop-in.Either IH offered a kit back from day one,or WIX realizes that kits exist and must be pretty popular.That filter also fits Bobcats and other equipment.
MN Scott
12-20-2004 19:23:58
Your local CNH dealer can order the spin on kits. They consist of a spin on base that mounts to the filter base in the block. There are no hoses involved. Cost is around $50.
Paul A.
12-21-2004 03:42:15
 Re: Spin On Filters in reply to MN Scott, 12-20-2004 19:23:58
Do they also fit the letter series tractors, or is there a different adapter for them? That would make changing oil filters a lot easier!
MN Scott
12-21-2004 18:32:53
 Re: Spin On Filters in reply to Paul A., 12-21-2004 03:42:15
CNH makes the kits for all IH engines that had canister type oil filters. Different part numbers for different engines, but the same basic design. Not sure if they all use the same spin on filter though.
CNKS
12-20-2004 19:07:45
If you are talking about the engine oil filter, there is no advantage to changing, except maybe a minute less work. To answer your question, yes there are kits, someone else can tell you where.
