Order Farmall Cub Parts Online
cub 12 volt conversion alternator position
hawkins1017
12-20-2004 22:04:17
my cub was converted to a 12 volt system but the alternator just doesnot sit right. i have looked at building a new bracket to hold the alternator but i dont know if i should try to raise the unit higher to get it under hood or just lower to clear hood. i prefer to hide it but any thing is better than it is. my hood has been cut to allow room for the alternator to hang out i want it to look as close to orignal as possible to do so i need all sheetmetal in place and the emblems. right now it just wont work.. help.. thanks for all the help so far..
Bus Driver
12-21-2004 05:01:58
 Re: cub 12 volt conversion alternator position in reply to hawkins1017, 12-20-2004 22:04:17
The Delco 10si will fit under the hood of the cub without any modifications to the hood. I did make two base brackets to get it right. The first one was close to correct and helped me make the second one correctly. The tensioning bracket is a bit tricky. Made 3 of those to get a good one, having a vertical milling machine to cut the adjustment slot helps. Some adjust the belt with a slotted base and the alternator is moved up and down for belt adjustment. Mine adjusts the regular way. Plan to use generator belt # 358 213 R1. The alternator pulley must match for width.
little john
12-21-2004 04:40:00
if you decide you want the japanese alternator, i just put one for sale in classifieds...should show up today.
Hugh MacKay
12-21-2004 03:31:52
hawkins: I have not had any experience with the Cub, but on my Super A I had to overcome position problems to avoid cutting hood and still make it look decent. I achieved this by using a double pulley from a V8 Olds or Buick. Not saying this will work on Cub, but may be worth a look.
The other solution you see, with some Farmalls is using a smaller alternator. From some Japaneese cars, Toyota and Nissan for example. I guess it is a Hitashi alternator. Just some thoughts, someone will come along with exact solution.
