'41 H
H Thompson
12-21-2004 03:30:45
I have a '41-H engine in need of rings and 1 piston. Where can I find just rings and pistons, not the entire engine overhall kit? I dont want to change sleeves. I would like to find 10 or 20 over rings, but would settle for standards. Thanks Harry.
captaink
12-21-2004 07:28:21
 Re: '41 H in reply to H Thompson, 12-21-2004 03:30:45
You can do what you like, but if your cylinders are worn enough that you are looking for 0.010” or 0.020” over rings, you probably have enough taper in those cylinders that the rings won’t last very long or the compression (and oil) will sneak by between the piston and the rings anyway.
Jim J
12-21-2004 05:16:45
Do you have any numbers off of your old piston? I have a few used pistons. Email me with the info and I will check my pistons.
Slappy
12-21-2004 04:54:36
Try your local IH/CNH dealer, they may allow you to buy the parts you need. You might try contacting some of the other after market sources like TISCO and OEM, as well as those on this site and see. Seems to me that you ought to be able to buy pistons and rings without the sleeves.
Andy Martin
12-21-2004 15:04:00
 Re: '41 H in reply to Slappy, 12-21-2004 04:54:36
Your local auto parts store can get rings and probably pistons, one at a time, but I agree you should mic the cylinders so you know what you have.
