That muffler reminds me
Steve W (NY)
12-21-2004 08:54:32
Does anyone make a decent quality quiet muffler for a BN (same as an A or B)? I bought one of those cheapies from TSC, and it is just too loud. I want a quiet tractor. My hearing is valuable, plus my neighbors and families peace is important.
Thanks in advance,
Steve
gene b
12-22-2004 01:39:43
 Re: That muffler reminds me in reply to Steve W (NY), 12-21-2004 08:54:32
I went to a muffler shop and got a piece of pipe that went into the outlet welded a plug on the end and drilled holes in the side and then stuck it in the outlet sure did quiet it down. Some mufflers you get for replacement will have a baffle in so you cannot see thru and these are quiet. Original had small outlet and baffle.
CNKS
12-21-2004 09:45:23
OEM Tractor Parts has an "original look" muffler for $42, don't know about the sound. Mark's Tractors sells original look and sound mufflers for $79. I have two of those, they are as advertised. The C113/123 won't make much noise with these mufflers.
Bob M
12-21-2004 09:23:37
You might try at Carter & Gruenenwald. I could not stand the racket from the TSC mufflers I had so I ordered a pair from C&G to replace 'em with.
They don't look exactly original (the main "can" part is half again as long as the TSC muffler) but they are wonderfully quiet. And after 4 years of service they are still silver - unlike the the TSC's which began to rust immediately after the first use.
Gotta think C&G stocks an equivalent quality muffler to fit your BN...
WulffMan
12-21-2004 12:24:03
 Re: That muffler reminds me in reply to Bob M, 12-21-2004 09:23:37
Try Mike at steel wheel ranch...I bought a B muffler from him for $20 (shipping was cheap too) and it is as quiet as any other I have had. Have had it on the tractor for about 3 years and it only has very minor rust at the seam. If you call Mike he can answer just about any question about the muffler you might have.
WulffMan
12-21-2004 12:25:04
 Re: That muffler reminds me in reply to WulffMan, 12-21-2004 12:24:03
here's the link to steel wheel ranch website
