injection pump leak
oldsledguy
12-21-2004 11:16:31
I"ve got a IH 600 Diesel and there is diesel fuel coming out of the imjection pump between the engine and the pump.Whats back there that could be leaking and how much of a job to fix?Thanks
Geoff NY
12-21-2004 19:03:55
 Re: injection pump leak in reply to oldsledguy, 12-21-2004 11:16:31
What I have found is the sealon the shaft that runs the "primary" pump (not the injector pump itself) has a small seal that leaks. Usually the seal dried out from sitting. The seal and new gaskets run less than $50. Not a hard fix. I suggest changing the main seal between the pump and the motor as well.
oldsledguy
12-21-2004 19:31:38
 Re: injection pump leak in reply to Geoff NY, 12-21-2004 19:03:55
Thanks I was hoping it was something easy.
