Order Farmall Cub Parts Online
Oil pressure on 1949 Farmall Cub
Tractor Man
12-21-2004 16:52:03
What is the proper oil pressure for a 1949 Farmall Cub? Anyone know? Thanks, Tractor Man
Bigdog
12-21-2004 17:40:34
 Re: Oil pressure on 1949 Farmall Cub in reply to Tractor Man, 12-21-2004 16:52:03
I've seen 'em run all over the place. I've seen some run 5 -10 pounds at hot idle and never make a noise or use a drop of oil. If you have 15 to 20 pounds you have plenty for that C60 engine. I think the original unmarked gauges were 0 - 40 or 45 pounds. They normally idle hot at mid scale or just below.
