Yes, I'm Too Picky
Allan in NE
12-22-2004 10:50:54
However,
Has anyone have one of these original IH CAT II center link attaching pins with the welded plate and dowel pin hole? Trying to make a 966 like new again.
Thanks,
Allan
third party image
Allan
Jrry
12-23-2004 06:45:47
 Re: Yes, I'm Too Picky in reply to Allan in NE, 12-22-2004 10:50:54
Allen, what did you decide about discussing the hydraulics measurement with your machanic?
captaink
12-22-2004 12:57:00
I have the one that came with my 966.
Allan in NE
12-22-2004 14:19:57
 Re: Yes, I'm Too Picky in reply to captaink, 12-22-2004 12:57:00
Just emailed, ya.
Thanks,
Allan
JT
12-22-2004 12:34:08
Allan,
I will look and see what we have around this weekend. It would be off of an 806or 1206 though. do not know if if will be the same as your 966. No that is not being picky. IH would not have used it if there was not a reason for it.
Jim
williamf
12-22-2004 15:20:42
 Re: Yes, I'm Too Picky in reply to JT, 12-22-2004 12:34:08
You're right. I believe the reason is that without the dowel the pin can turn in the bracket instead of in the bushing in the end of the link. That would wallow out the holes in the bracket, more expensive than a new bushing.
Wm
JT
12-22-2004 15:58:14
 Re: Yes, I'm Too Picky in reply to williamf, 12-22-2004 15:20:42
Wm,
If that is not the correct reason, it sure sounds reasonable to me.
Allan in NE
12-22-2004 16:22:44
 Re: Yes, I'm Too Picky in reply to JT, 12-22-2004 15:58:14
Hi JT,
Yepper, he's gotta be right about that. Put a nice big heavy implement on that 3-point and that ol' center link is a workin' pretty hard.
Sure wouldn't take long to wobble out that cast bracket mount.
Allan
