350 farmall
Leem
12-22-2004 11:26:56
Was wondering, how can I tell the difference between a 300 and a 350, excluding the paint,emblems thanks Max
Redgreen Man
12-22-2004 13:19:34
 Re: 350 farmall in reply to Leem, 12-22-2004 11:26:56
The 300 will have the key ignition switch on the middle of the dash with a flip down cover over it, they start with the key. The 350 has the switch on the left side under the dash, and the starter button is on the dash.
sammy the RED
12-22-2004 12:24:48
Serial number.
Casting codes.
Motor.
Evan
12-22-2004 12:50:18
 Re: 350 farmall in reply to sammy the RED, 12-22-2004 12:24:48
Also, if fitted with a Fast Hitch, they are rather different between the 300 and 350. On the 300 FH, the lift hangs from an arm bolted to the deck next to the battery box. The 350 FH lift instead pushes off from low under the PTO housing.
