Carb on an
Seb
12-22-2004 13:29:51
Need to rebuild or purchase a new Carb. Problem is findingh a rebuild kit or new one for this Carb.Its off a Farmall 1946 "A". It is a number I cannot locate. Type is, Carter UT. On the flange at top is the # 0653. Any help locating this part would be appreciated. Their are no other plates or #s Thanks
BIG JOHN
12-22-2004 16:42:18
 Re: Carb on an in reply to Seb, 12-22-2004 13:29:51
Just take it with you and go to your local IH dealer. These parts are still available thru the dealers. There are more than one model so taking it with you will insure that you get the right parts.
GOOD LUCK
John *.?-!.* cub owner
12-22-2004 15:59:37
Try contacting ken Updyke at www.cngco.com. (Carter & Gruenwald).
