hydralic lift
iester
12-22-2004 16:06:33
lift raises slow at low rpm.increase rpm and it raises faster. is this normal?
PAULIH300
12-22-2004 18:35:15
 Re: hydralic lift in reply to iester, 12-22-2004 16:06:33
Does it whine or growl while its lifting?
old
12-22-2004 16:40:06
Think of it this way the faster you pump a hand water pump the faster you fill a bucket with water. Works the same way for hyd. systems faster RPM more gpm
iester
12-22-2004 17:04:12
 Re: hydralic lift in reply to old, 12-22-2004 16:40:06
sorry.i am a little hard headed.so that is normal?
CNKS
12-22-2004 17:21:07
 Re: hydralic lift in reply to iester, 12-22-2004 17:04:12
It's normal if you are satisfied with the speed it raises at idle -- I suspect you aren't. What tractor are you talking about?
iester
12-22-2004 17:33:06
 Re: hydralic lift in reply to CNKS, 12-22-2004 17:21:07
it's a 1957 ih 350 utility (175 cid)
CNKS
12-22-2004 17:53:11
 Re: hydralic lift in reply to iester, 12-22-2004 17:33:06
First thing change the fluid and filter, if that does not help you may have internal problems. I have a 460 utility, which replaced the 350, currently disassembled, not that familiar with either one. Mine was 1/3 full of water.
iester
12-22-2004 17:32:20
darin
12-22-2004 18:29:06
 Re: hydralic lift in reply to iester, 12-22-2004 17:32:20
you should do a pressure check on the system first then you can check the screen where the lines go into the resivoir ,may be plugged.hy tran fluid has a waxy content that can cause a build up there.also pressure regulator valve or safty valve or aweak pump.
mark k
12-22-2004 21:32:13
 Re: hydralic lift in reply to darin, 12-22-2004 18:29:06
Hello,
You need to check the suction screen, it is a pain to do because of that it probably hasn't been done before. It is under the seat the the lid is very heavy and needs to be lifted straight up so you don't break the screen or anything. Mine has problems but it is with the pump I have a 350U also. Have a good one. Mark
