1966 farmall 140 water leak
Huston Lloyd
12-22-2004 20:56:45
I was pulling gravel in my driveway on day and all of a sudden smoke and water was pouring out of the bottom of the engine by where the bellhousing meets the engine, is this maybe soft plugs and how hard is it to repair.
next question where can u buy jacks so i can re-due this tractor this winter.and what is the jacks called. and where can i buy used ones?
thanks
Huston Lloyd
12-23-2004 10:15:37
 Re: 1966 farmall 140 water leak in reply to Huston Lloyd, 12-22-2004 20:56:45
thank you all so much for your input i will check and see what i can come up with and take pic and post it
Huston
lee
12-23-2004 08:51:27
I use a 10 x10 overhead bridge crane set-up. Run one chain fall off a bridge beam trolley to a point just ahead of the split point. The second chain fall off a seccond trolley on the bridge beam to a point behind the split point. Split the tractor and roll the sections apart.
Bill in NC
12-23-2004 09:37:31
 Re: 1966 farmall 140 water leak in reply to lee, 12-23-2004 08:51:27
Lee,
Sounds like a nifty method for safely and conveniently splitting a tractor. Can we talk you into posting pictures of your bridge-beam hoist(s) set-up sometime?
lee
12-23-2004 10:07:17
 Re: 1966 farmall 140 water leak in reply to Bill in NC, 12-23-2004 09:37:31
Only drawback is it costs about $1,200 to build
if you buy all the stuff new and of good quality. And you need a place to set it up. But you can do it cheaper I'm sure if you're smarter than I am.
I've removed/installed automotive engines and done other things with it to help justify the cost which I try not to have to justify costs anyway.
lee
12-23-2004 09:56:16
Right now I don't have any pics but maybe I could get some in the future.
Hugh MacKay
12-23-2004 02:51:43
Huston: All I use is a bottle jack along with a pallet jack. I keep a number of good hardwood pallets, some 2, 4 and 6 inch blocking and ratchet tie down straps. In splitting my 130 at the clutch housing, here is my proceedure; Put wedges in oscillation point of front axle, choke rear wheels, place a pallet under front end of tractor. Block in from pallet to each side under axle and to oil pan just ahead of clutch housing. I build a cradle so sides of block take weight and not oil pan. I then use shim material so when I jack pallet all 3 stacks of blocks make contact at same time. raise pallet jack so blocking is tight. Apply ratchet straps from tractor to pallet at 3 points. Now the front of tractor and pallet are one piece. Just place the bottle jack under clutch housing to take weight. You are ready to unbolt and separate tractor. The beauty of this you can wheel the entire front end out of your way and use pallet jack for another move.
I have split tractors as large as 560 with this. If you have enough pallets, blocking and tie down straps you can dismantle your entire tractor component by component. I have removed 20.8 x 38 tires and wheels, full of calcium chloride, in a standing position, using pallet, blocking and 4 tie down straps. I wouldn't be afraid to split a 150 hp tractor using this.
As you know I have quite a few implements for my offset tractors. For winter storage I just set them on pallets, using the jack I can manuver them places I could think of with tractor. My advice is buy the pallet jack then the tractor. Wouldn't be without that pallet jack.
Bill in NC
12-23-2004 09:34:40
 Re: 1966 farmall 140 water leak in reply to Hugh MacKay, 12-23-2004 02:51:43
Hugh,
Great idea about pallet jack and storing implements! I'm jealous, you obviously have a large concrete floored area inside your barn for pallet jack manuvering. Your set-up for splitting a tractor sounds safe and simple. Can we talk you into posting pictures next time you split one of your tractors? I'd love to see your set-up from the side and the front.
Farmall Don
12-23-2004 08:15:51
Im glad you shared this idea with us. I must have missed this suggestion in the past. Guess what Im going to shop for this chrismas (for myself that is). I could use one for my organic food business anyway, rather than using forks on my loader all the time. I wonder if I can write it off then?
