runs rough 434 international
R baker
12-23-2004 06:26:17
it ran great in summer not so good in winter carb freezes quickly then has no power. it will sit and idle allright but can not move without dying out. can you help?
old
12-23-2004 07:21:07
 Re: runs rough 434 international in reply to R baker, 12-23-2004 06:26:17
Cover that side of the engine so the heat from the engine keeps the carb warm. Or even better get a tractor heater cab for it, it will keep the carb from iceing and also help keep you from iceing up also
parts man
12-23-2004 15:46:33
 Re: runs rough 434 international in reply to old, 12-23-2004 07:21:07
Those BC144s were cold blooded PIGs!!! Had to run with the choke on pretty well all winter. Once the engine warms up good the carburater icing usually stops too. ;)
