C221 -C301 gas heads
460anger
12-24-2004 07:44:01
I have a C291 engine that I"m going to bore and use the 301 pistons. I don"t ever see anything about the heads. I have a head from a 221 and a 291, which would be better to use? Haven"t measured valve size , for they"re still on the engines. Same for cams. Also need to know where I can find a 301 combine carburator. Thanks!
EJR
12-24-2004 11:15:18
 Re: C221 -C301 gas heads in reply to 460anger, 12-24-2004 07:44:01
Cams are the same the 301 has the bigger intake valves.The combine carb inlet faces to the back of the engine if that makes a difference.291 has sleeves with a 33/4 bore,301 is sleeveless at 313/16 they make a 60over 301 piston still available at case ih.Im working on a460 now putting in a 301.
