gas 221..263....460/560
d clubb
12-25-2004 17:13:58
I need to knoe if 560 gas engine wil work in 460.....i have a ih combine engine will it work in 460,,how can i tell diff in 221 and 263....thanks
Redrider
12-25-2004 17:58:16
 Re: gas 221..263....460/560 in reply to d clubb, 12-25-2004 17:13:58
clubb, The blocks are identical for the 221 through the 301. Longer stroke crank is the difference 221 & 263. longer stroke crank and no sleeves for the 301
clubb
12-26-2004 05:11:38
 Re: gas 221..263....460/560 in reply to Redrider, 12-25-2004 17:58:16
would the combine 221/263 also be same engine..thanks dean
ChadS
12-26-2004 13:42:17
 Re: gas 221..263....460/560 in reply to clubb, 12-26-2004 05:11:38
It will bolt right in,, you will have to change the front timing covers from the combine to the tractor engine. Everything else is bolted on accesories that all interchanges. ChadS
dean c
12-28-2004 03:58:16
 Re: gas 221..263....460/560 in reply to ChadS, 12-26-2004 13:42:17
thanks for you help
