200 head torque
jerryl
12-26-2004 20:38:07
my book does not give head torque does anyone know what it should be and the right order would be helpful thanks for any replys
El Toro
12-27-2004 03:22:32
 Re: 200 head torque in reply to jerryl, 12-26-2004 20:38:07
Hi Jerry, That torque is 80 ft-lb and start in the center of the head after you tighten the the nuts or bolts with a speed handle or a ratchet
lightly. Using a torque wrench tighten with 25 ft-lb using a criss-crossing pattern. Increase the the torque 15 to 20 ft/lb and keep going back to the center and use that same criss-crossing pattern until you finally reach 80 ft-lb. After
you have run the engine retorque the the head again and check your valve clearance.
Use a pattern similar to this: Hal
----- ----- -9--5---1--3--7--11----- ----- ----- ----- ----- -10--6---2--4--8--12----- ----- ----- -Note: This pattern is going to shift, No1&3 are
over 2&4.
