Purpose of Tie Rod Clamps on farmall 100
Ramon from NC
12-27-2004 13:54:03
What is the functional purpose of the tie rods clamps on a Farmall 100. Are they only for disassembly or do you tweak them for some sort of performance adjustments? Thanks Ramon
Hugh MacKay
12-27-2004 15:02:31
 Re: Purpose of Tie Rod Clamps on farmall 100 in reply to Ramon from NC, 12-27-2004 13:54:03
Ramon: With out the clamps you could not have wheel tread or toe in adjustment. The clamps one outer end give you 2" inkrements as per your axle adjustment. The inner clamps on the threaded tie rod end enable you to correct toe in.
Andy Martin
12-27-2004 14:46:37
They are to adjust the tie rods to match the axle setting. The front axle is adjustable to match the rear tread selected for row crop work.
Perhaps yours are set all the way in.
