Super C hyd. lines
JimBub
12-27-2004 14:12:22
Bought hyd. lines advertised for Super C. Not the same tubes as mine with fast hitch. Does the regular C and Super C use this same double line tube and a fast hitch tractor changed for rear control?
Lewis
12-27-2004 15:22:46
 Re: Super C hyd. lines in reply to JimBub, 12-27-2004 14:12:22
Hi Jimbub,
I have the hydraulic lines for the Super C with fast hitch if you are interested.
El Toro
12-27-2004 15:07:35
Hi Jim, I had to change the hydraulic lines on my Super C and I made them up myself. I used Alemite braided hose with 5/16" flare swivel nuts. I think I changed the fittings too, so they would accept the new hoses. It's been a long since I did that. One of the lines blew when I finished plowing and I tried to raise the plow and the line blew. So I changed both lines, it's a very easy job to change thes hoses. I think the block had 1/4" female pipe threads too.
Hal
Milan
12-27-2004 14:47:22
the difference is in the block at the end of the tubes that attaches to the touch control housing. the one for a fast hitch is milled on the backside to accept the remote actuator.
Jimbub
12-27-2004 14:59:28
 Re: Super C hyd. lines in reply to Milan, 12-27-2004 14:47:22
Thanks Milan,Been checking the archives,these are not what I need. My tractor is running,line is spliced with hose just wanted to go back to orginal! I,ll keep looking!
