Bosch #'s for starter in above post...
fixitforfree
12-27-2004 20:12:22
These are the numbers on the starter in the above post:
Bosch
0 001354107
JD - 12V18PS 030
L20597
Bruce Wa.
12-28-2004 08:38:25
 Re: Bosch #'s for starter in above post... in reply to fixitforfree, 12-27-2004 20:12:22
Replaced the lucas starter on my 385 with a delco.cranks way faster and starts easily.
El Toro
12-28-2004 05:32:08
If the heavier battery cables doesn't solve the cranking problem find a shop that rebuilds starters, generators and altenators. Call around and find a shop that can load test that Bosch starter. It would help your starting by installing a block heater to preheat the engine
this would require less starting amperage. Try
Phillips & Temro at 1-800-328-6108 for a heater.
They can give you a distrbutor in your area. Hal
El Toro
12-28-2004 04:01:08
Try getting some heavier cables with exact length
that's needed. Welding suppliers have heavy
cables and where truck tractors supplies are sold too. Replace cable from battery to starter and the ground cable too. Those diesels draw a lot of current when cranking and will improve the cranking speed with the heavier cables.
