Farmall H carb Manifold
Tom Harvey
12-28-2004 07:57:23
My Uncle purchased a farmall I4, the manifold, Carb & distributor has been stolen off the tractor. I purchased a manifold from ebay from a person I have purchased a lot from and I have had good luck. It stated it fit a H, SH, 200, 350. My cousin his son, purchased a farmall H carb. The manifold lines up good but the carb is to small to bolt on the bottom of the manifold. I see where you purchase tractor parts that the carb for the H and SH are different but the manifold is the same? We think that the manifold is from a newer tractor than the H and that it takes a larger carb. I have a H I farm with and the carb number 6212DB on the side is the same. We can not make out the number on the manifold but the number on the inside next to the engine is 316A...We are in no hurry so any info on the manifold would be good I am sure we can sell it and get another or sell the carb and get a different one..
Thanks TOm in Maine
PS my Uncle who still farms (10 acres of Dried Beans) farms with two Farmall M's one of them is the tractor his father purchased when my Uncle was just 17
deweed(TX)
12-28-2004 15:19:12
 Re: Farmall H carb Manifold in reply to Tom Harvey, 12-28-2004 07:57:23
I just replaced the manifold on my '46 H. My parts guy says the old style is no longer available, but this one is made to fit several models. The holes for the carb mount are slotted for the different size carbs. I was concerned at first but all went well and she's never run better.
MagMan
12-28-2004 08:32:02
The newer aftermarket manifolds say that they will fit H and SH The only way I could think would be if there was extra holes drilled in the manifold to acept the smaller H carb You would move the studs in or something I sell them but have never looked at one . The H carb is smaller than the SH,300,350. If its a stock SH manifold you could always go with the SH, M carb. JON
kfox
12-28-2004 12:16:14
 Re: Farmall H carb Manifold in reply to MagMan, 12-28-2004 08:32:02
Does your manifold look like this one? This is one of the aftermarket manifolds made to fit H through 350. I think the slotted bolt holes will fit all the carb sizes.. ken
http://www.tractorshed.com/cgi-bin/gallery/iphoto_pic.cgi?
James Wall
12-28-2004 16:02:26
 Re: Farmall H carb Manifold in reply to kfox, 12-28-2004 12:16:14
I put a new manifold on my42H this year and the bolt holes on the aftermarket one I bought was oval also All I had to do is use a smaller bolt to line all up has ran like a champ `
kfox
12-28-2004 12:18:37
Sorry I haven't mastered the photo posting on this board yet. Trying again ken
