M drive shaft coupling question
Stroked550
12-28-2004 21:03:37
Just replaced the clutch in a "51 Farmall M, the wavy looking plate that connects the trans yoke to the clutch shaft was worn almost through. Picked up 4 of the tapered bolts from the IH dealer and a new coupling plate from a salvage yard (dealer wanted $80 for it). Now that its all back together I noticed the replacement plate is thinner than the orig.- it has about 3/16" of play. Should I try and find a thicker plate or is it good as is?
Thanks
Ben
captaink
12-29-2004 07:24:20
 Re: M drive shaft coupling question in reply to Stroked550, 12-28-2004 21:03:37
Get the right parts. There should not be any play in there at all other than the give from the rubber washers. Otherwise the clutch shaft could move back and forth in the clutch disk and pilot bearing.
My 2 cents...
Merle Hoppenworth
12-29-2004 05:34:17
Just restored a Super H and I can tell you that if that coupler and the tapered bolts aren't tight it will result in a noisy coupling. Can even sound like a bad bearing in transmission.
My .02 cents worth.
